It is currently Thu Apr 10, 2025 8:25 pm
PostPosted: Thu Sep 27, 2018 12:24 am
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
A customer wants me to change out his pots on an offshore PRS. The posts on the alpha pots in the guitar are a little smaller than on the CTS ones I have. Any tips on making those holes bigger without chipping the poly? I’ve done it before on lacquer finishes by filing the rim of the hole a bit and then drilling backwards without any issue but would like to head any potential problems off at the pass.
PostPosted: Thu Sep 27, 2018 9:12 am
This is what tapered reamers are for.
These users thanked the author Barry Daniels for the post (total 2): Conor_Searl (Thu Sep 27, 2018 10:20 am) • DanKirkland (Thu Sep 27, 2018 9:15 am)
PostPosted: Thu Sep 27, 2018 10:23 am
First name: Conor
Last Name: Searl
City: Duncan
Gotcha. Thanks Barry. While I wait for a tapered reamer to show up in the mail, (since I doubt I'll find one in town) would working up to the size of hole I need with drill bits amount to the same thing?
PostPosted: Thu Sep 27, 2018 10:26 am
From experience, wait for the reamer. Drill bit's have a much higher chance of chipping things than the rramer.
PostPosted: Thu Sep 27, 2018 10:29 am
Last Name: Schreiner
City: Miami
State: FL
Zip/Postal Code: 33183
Chipping the finish is the issue it seems. I would use a dowel wrapped with 80 grit sand paper and use a push stroke only.
Michael
PostPosted: Thu Sep 27, 2018 11:10 am
Rat tail file, sandpaper on a dowel, etc. Drills just invite cracking of finish.
PostPosted: Thu Sep 27, 2018 11:30 am
First name: Conor
Last Name: Searl
City: Duncan
Awesome thanks guys. Those are great suggestions.
As an aside, Stew Mac has tapered reamers for a variety of jobs and they are all around $80. Allparts has one generic reamer for about $6. Is there actually $74 difference in the quality? I'm pretty new to buying tools and I have noticed that you get what you pay for most of the time, I've also noticed the other part of the time you can buy really shiny looking toys.
PostPosted: Thu Sep 27, 2018 2:30 pm
Stew Mac reamers only have cutting edges on one half of the body that prevents chattering, which is a very rough hole with large ridges on the sides of the tapered hole. It makes a huge difference.
PostPosted: Thu Sep 27, 2018 3:16 pm
Those are called violin peg reamers. I have early ones with 1 flute for precision sizing.
PostPosted: Thu Sep 27, 2018 6:41 pm
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
Don't forget the step drill. It may look nasty ut it does a very clean job every time with little or no chipping.
Get the one with 1/2" max diameter:
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
These users thanked the author Frank Ford for the post: Conor_Searl (Thu Sep 27, 2018 9:01 pm)
PostPosted: Thu Sep 27, 2018 11:38 pm
Frank won't steer you wrong.
PostPosted: Thu Oct 04, 2018 2:44 am
Just playing devils advocate here but why not buy some new Alpha pots that fit the existing holes? Replacing the Alphas with CTS pots with make no difference to the sound unless they are faulty or of a different value to the replacements.
PostPosted: Thu Oct 04, 2018 8:41 am
Because Alpha pots are crap?
PostPosted: Thu Oct 04, 2018 10:25 am
First name: Conor
Last Name: Searl
City: Duncan
Yeah, I know. The guitar was a PRS SE and the wiring was solid, clean, and well done, and I told my customer as much. But he wanted the upgrade. So I did it. The first thing he did when he picked up the guitar was roll the volume knob and said wow that feels better. :)
These users thanked the author Conor_Searl for the post: Bosco Birdswood (Thu Oct 04, 2018 5:31 pm)
PostPosted: Sun Dec 09, 2018 9:35 pm
First name: Mark
Last Name: Wong
City: Orangevale
State: CA - California
Zip/Postal Code: 95662
I use a dremel to enlarge them. Very precision edge that way.
These users thanked the author Photoweborama for the post: Conor_Searl (Mon Dec 10, 2018 12:42 am)
PostPosted: Mon Jan 07, 2019 3:54 pm
First name: Dan
Last Name: Savage
City: Trabuco Canyon
Zip/Postal Code: 92679
If you don't want tapered holes, you can use a model airplane prop reamer. These work extremely well for cleaning up tuner holes in head stocks, etc.
Available from Tower Hobbies for $15 each.
Metric - 7mm, 8mm, 10mm (the first step is 1/4" (6.35mm)): https://www.towerhobbies.com/cgi-bin/wt ... XEGH6&P=ML
SAE - 1/4" 5/16" 3/8": https://www.towerhobbies.com/cgi-bin/wt ... XEGH7&P=ML
